How do I add the admin user to the license server (sesinetd) 21.0?
If you are looking to configure license partitioning or webhooks, an admin user must be added to the sesinetd license server.
You can either edit sesinetd.ini on the server or you can do your edits within the Settings tab in the License Administrator.
The sesinetd.ini file is located in the location based on your operating system:
Windows: C:/Windows/keys Linux: /usr/lib/sesi OSX: /Library/Preferences/sesi
Two items must be setup in order to create the admin login:
- The SSL certificates
- The admin password
You can use sesictrl to configure both the SSL certificates and the admin password for sesinetd by adding the variables to the sesinetd.ini file.
Add the following to the sesinetd.ini file:
enableSSL=true sslCertFile=/usr/lib/sesi/cert.pem sslPrivateFile=/usr/lib/sesi/private.pem superuserPassword=
The above example is using Linux file paths. Edit your SSL files for your operating system location.
If no admin user is specified, the username "admin" is used by default. To change the admin username:
Ensure the permissions of the file are owned by the user running the license server daemon. This is the default user and group specified in sesinetd.ini.superuserUser=admin
To change the default username, add the superuserUser variable.
To generate the superuserPassword value:
sesictrl hash-password your-password
Copy the full string to the superuserPassword variable in the sesinetd.ini file.
Type
sesictrl hash-password --helpfor more options.To generate the SSL certificates:
sesictrl gen-certificate
Copy the file locations to the sslCertFile and sslPrivateFile variabls in the sesinetd.ini file. Ensure the sesinetd user has access to read the SSL files.
Type
sesictrl gen-certificate --helpfor more options.Whenever making a change to the sesinetd.ini remember to restart sesinetd.
Once your admin user has been created and you are able to log into the Server View portion of the License Administrator, you can select the Accounts tab and the Create button to add additional users.
