How can I run sesinetd on a different TCP port?
The default port for the license server service or daemon is TCP 1715.
If absolutely necessary, it can be changed by editing the license server sesinetd.ini configuration file.
Add or edit the following option to the sesinetd.ini configuration file :
port=value
Where value is the new port number for the license server.
When making changes to the sesinetd.ini file, ensure to restart the license server service or daemon.
Note that any computers pointing to the license server will need to specify "servername:port" when running on a non-default port.
