Fireplace
   19437   19   2
Hi! Im working on a fireplace scene where flames raise from a group of logs. Im using PyroFX as the solver and also the Pyro shader included in Houdini.
At the moment im having trouble getting the right shape for the flame, i want it more “swirly” but i always get a pretty straight flame.
I`ve done many pre tests, and here is part of the WIP
Tests:
01 - http://vimeo.com/30167942 [vimeo.com]
02 - http://vimeo.com/30273837 [vimeo.com]
03 - http://vimeo.com/30314817 [vimeo.com]
04 - http://vimeo.com/30405207 [vimeo.com]
NicoZ
New test with less divisions (120) and more speed and turbulence
http://vimeo.com/30624284 [vimeo.com]
NicoZ
Coo! I like the evolution but I prefer the color scheme on the initial tests. Somehow the reds look over saturated to me.
Toronto - ON
Thanks rafaels, i forget to say that the last one is the temperature plane and not the shader color
NicoZ
right, I see now!
Toronto - ON
Another test, in this one i think i have a problem with scale xD
http://vimeo.com/30765230 [vimeo.com]
NicoZ
Yes, I think the scale is a bit off too..
The other thing is those flying particles, I think they are too slow, maybe you should try advecting them with the fire. I'm not exactly sure of how that works in pyro, but shouldn't be that complicated. Also they should start bright and fade out as they burn, what you think?
Toronto - ON
Yeah, thats right, tonight ill let the sim and render to finish with some new tweaks to fix the scale thing.
Those particles are really raw. I added for the tests but i didnt work on them already. Yes, the idea is once i have the final fluid, ill advect them, and some of the will “explode” just like the wood hot particles do.
So, looking forward to what ill see in the morning
NicoZ
Here is a new flipbook of the density and heat
http://vimeo.com/30888878 [vimeo.com]
NicoZ
New video of the first render of the shaders for the scene. Still on Shader Quality 1
http://vimeo.com/31194517 [vimeo.com]
NicoZ
Here´s a preview of the shaders.
The light is based on the fluid (but in this one not rendered)
NicoZ
Curious to see your result.
Maybe can you decrease the intensity of the actual light and maybe strat to make a night mood to your base lightset …
http://vimeo.com/vbkstudio [vimeo.com]
Here is a still from the final render, I think next week ill finish it
NicoZ
cool render, i like it
super
Just finished this mini project. On to the next
http://vimeo.com/32652010 [vimeo.com]
NicoZ
I really like the final result.
May i suggest some fire-glowy cavities on the wood just to give it a sense that its really on fire, I think it will increase the level of realism even more. Either way, top notch work.
“And those who were seen dancing were thought to be insane by those who could not hear the music.”
Thanks Gerlandox, I appreciate your observation and like the idea, for this one i´ll leave it this way but for my next projects i´ll study more in depth the shading.
Other thing that may work is some areas of the wood with white ashes on the outside.
NicoZ
Definitely!
Im so considering to make smth like this myself, an in door fireplace maybe. Its a nice walk-through-features for Houdini newbies. thx man
G
hey guys…
i have big problem in houdini and try over and over again and i take anything!!!
my goal is create fire and dens smoke but when i increase smoke amount to 50 of more smoke get around of fire but i don't want it.
i want to smoke just available right top of my fire.
here one picture of my problem:
how can i remove smoke from red area?
