Hi
How do i create a smoke bomb??
My problem is that i have to get out of a very small things a lot of smoke.
Make a Smoke Bomb
4460 3 1-
- MarcoDelVecchio
- 9 posts
- koen
- 798 posts
- MarcoDelVecchio
- 9 posts
- koen
- 798 posts
you can just use a second fluid source, and source into the divergence field instead of the density. Scale up the values to get more effect.
Another way to set this up is with the expand from object tool on the “populate containers” tab.
The smoke and pyro solver should be pretty similar, but shaping your sim once you have the basics running will be simpler when using a pyro sim.
