I am evaluating Houdini to possibly add it to our game pipeline that already supports Maya, Max, Mobu and XSI.
I would like to execute a Python script to execute some logic and decide a specific dll to load at start. I get my logic to get executed at start (through $HOME/python2.6libs/pythonrc.py on Win7) but I can't seem to find the equivalent of, lets say, Maya's Python command: maya.cmds.loadPlugin().
Is it possible in Houdini? How?
Maybe it's not too late to copy a dll into a Houdini's lookup folder for plugins in the startup script?
Many thanks.
- Francois
Loading custom dll from Python startup script.
4327 4 1-
- chambordstudios
- 3 posts
- laiwayne
- 58 posts
set HOUDINI_DSO_PATH environment variable in your Houdini startup script.
http://www.sidefx.com/docs/hdk12.5/hdk_intro_creatingplugins.html#HDK_Intro_CreatingPlugins_HOUDINI_DSO_PATH [sidefx.com]
- chambordstudios
- 3 posts
- Infernalspawn
- 229 posts
you could use
hou.NodeTypeCategory's loadDSO() function.
I have not used it, and there is afaik no way to unload .dsos.
What laiwayne is describing is a often used way, where you have your .dso/.dll in different directories (e.g. a folder for each version). When your application is starting (BootStrap) up you remove/add theses paths to the HOUDINI_PATH/HOUDINI_DSO_PATH according to your needs (e.g. based on your shot/sequence/show env)
Infernal
Infernal
- chambordstudios
- 3 posts
