manually oriented normals for point velocity
   2182   1   1
EDIT: i would like to know also how to create angular velocity to transfer per piece
i am trying to orient manually normals to transfer them into point velocity for a choreographed RBD simulation.
Basically i create point clouds with uni directional normals, place them and rotate them accordingly to the direction i want the pieces to go, then transfer the normals onto my RBD fracture object.
Finally i vopsop normals into point velocities
it is working but i would like to know if there is a better/smarter way to do so.
here is an example file
thank you
manual normal orientation.hipnc (277.3 KB)
There is many solution to drive explosion with DOPs. One of these are with a magnet force. You can find solution in this forum or odforce forum.
But for info, i modified your file. Modifications are in red.
And for angular forces, look at the Point SOP. There are a lot of tab to setup those forces.
manual_normal_orientation_738_modif.hipnc (288.1 KB)
