Hi everyone,
I've stumbled upon the most curious bug. After tumbling around in the viewport gazing off into the vast nothingness of the empty space, I decided to create a sphere. As soon as I try to click anywhere in the view the whole application crashes. Multiple times, not just spheres. What may cause such a glitch?
“Caught signal 11”
Ubuntu 12.04
Houdini 12.5.371
All the best,
Elias Ericsson Rydberg
Clicking in Viewport causes crash in Ubuntu
6188 13 0-
- Elias Ericsson Rydberg
- 41 posts
- anon_user_37409885
- 4189 posts
- 41 posts
- Sadjad Rabiee
- 1391 posts
- chrism
- 2608 posts
Logging a bug with your graphic card and driver info would be great. Thanks!
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=25347 [sidefx.com]
Chris McSpurren
- 41 posts
I'm leaning on that the bug is with Ubuntu and the graphics driver, Houdini did run fine previously.
I'm afraid you're not correct Joker, I actually don't have a graphics card on this machine. I have an Intel i3 4130 that has integrated graphics. Houdini is still almost useable, as long as I'm not touching anything in the viewport, tumbling is fine and so is the other node panel etc.
I've tested to install xubuntu (xfce desktop ubuntu) to try to eliminate any effect Unity and Compiz might have. But to no avail, the error is persistant. Maybe this will give me a reason to learn how to restore from one of my backups on Ubuntu. Let's stay positive!
I'll try to reinstall any graphics drivers and such first though!
- malexander
- 5287 posts
- 41 posts
- chrism
- 2608 posts
Ahhh….an intel integrated graphics card. You're not going to have a good time with that, I'm afraid. Here's an excerpt from our System Requirements page:
“Non-workstation cards, such as GeForce, Radeon, and Intel integrated graphics can be used at your own risk. They may be used for learning and personal use but are not supported: you may experience display problems, slow performance, and the software may exit unexpectedly.”
http://www.sidefx.com/index.php?option=com_content&task=view&id=415&Itemid=269 [sidefx.com]
Chris McSpurren
- malexander
- 5287 posts
- 41 posts
I'm aware that's it not supported, but it did work perfectly. This machine is not supposed to be a workstation, its supposed to be a render slave and a fileserver. I'll buy the workstation next week, when the invoices get paid! :mrgreen:
Info for the curious:
OpenGL Vendor: Intel Open Source Technology Center
OpenGL Renderer: Mesa DRI Intel(R) Haswell
OpenGL Version: 3.0 Mesa 9.1.7
OpenGL Shading Language: 1.30
Viewport Render Version: GL 1.2
Detected: Mesa Consumer
Unknown VRAM
9.1.7.0
Unknown VRAM
9.1.7.0
- malexander
- 5287 posts
- 41 posts
Sure!
Here's one:
Crash report from elias; Houdini FX Version 12.5.371
Traceback from Wed Dec 4 20:08:46 2013
Caught signal 11
AP_Interface::coredumpHandler(UTsignalHandlerArg) <libHoudiniUI.so>
UT_Signal::UT_ComboSignalHandler:
perator()(int, siginfo*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo*, void*) <libHoudiniUT.so>
_L_unlock_16 <libpthread.so.0>
_tnl_RasterPos <libdricore9.1.7.so.1>
_tnl_run_pipeline <libdricore9.1.7.so.1>
_tnl_draw_prims <libdricore9.1.7.so.1>
_tnl_vbo_draw_prims <libdricore9.1.7.so.1>
vbo_rebase_prims <libdricore9.1.7.so.1>
_init <i965_dri.so>
_es_Materialf <libdricore9.1.7.so.1>
vbo_bind_arrays <libdricore9.1.7.so.1>
RE_OGLVertexBuffer::drawElements(RE_Render*, RE_PrimType, RE_OGLArray*, int, int, int) <libHoudiniUI.so>
RE_VertexArray::drawSomePrims(RE_Render*, RE_PrimType, RE_VertexArray*, int, bool) <libHoudiniUI.so>
RE_Geometry::drawPrivate(RE_Render*, re_Connectivity*, int, RE_PrimType, UT_PtrArray<char const*>*) <libHoudiniUI.so>
DM_SphereKnob::renderShaded(RE_Render&, int, unsigned int, unsigned int, UT_IntrusivePtr<RE_Material>) const <libHoudiniAPPS3.so>
MH_RotateHandle::renderShadedSphereKnob(RE_Render*, int, char, char, int, UT_IntrusivePtr<RE_Material> const&) <libHoudiniAPPS3.so>
MH_RotateHandle::renderTumbleKnobs(RE_Render*, int, int, int, unsigned int) <libHoudiniAPPS3.so>
MH_XformHandle::drawKnobs(RE_Render*, int, int, int, unsigned int) <libHoudiniAPPS3.so>
MH_PivotHandle::renderKnobsSetup(RE_Render*, int, int, unsigned int) <libHoudiniAPPS3.so>
MH_PivotHandle::doRenderPrivate(RE_Render*, int, int) <libHoudiniAPPS3.so>
MH_PivotHandle::doPickRenderActive(RE_Render*, int, int) <libHoudiniAPPS3.so>
DM_Handle::pickRenderActive(RE_Render*, int, int) <libHoudiniAPPS3.so>
DM_HandleList::pickRenderActive(RE_Render*, int, int, unsigned int, int) <libHoudiniAPPS3.so>
DM_SceneManager::dmPickHandle(DM_Viewport*, RE_Render*, int, int, void*) <libHoudiniAPPS3.so>
DM_Viewport::singlePick(UI_Event*, unsigned int, unsigned int*&, void (*)(DM_Viewport*, RE_Render*, int, int, void*), void*, unsigned int, GA_PrimCompat::TypeMask, int, unsigned int*) <libHoudiniAPPS3.so>
DM_SceneManager::singlePick(UI_Event*, unsigned int, unsigned int*&, void (*)(DM_Viewport*, RE_Render*, int, int, void*), void*, unsigned int, GA_PrimCompat::TypeMask, int) <libHoudiniAPPS3.so>
DM_SceneManager::pickHandle(UI_Event*, int) <libHoudiniAPPS3.so>
BM_Viewport::beginSelect(UI_Event*) <libHoudiniAPPS2.so>
DM_Viewport::beginSelect(UI_Event*) <libHoudiniAPPS3.so>
UI_Window::handleEvent(UI_Event*) <libHoudiniUI.so>
UI_Queue::processNextEvent() <libHoudiniUI.so>
UI_Queue::drain() <libHoudiniUI.so>
UI_Queue::eventLoop() <libHoudiniUI.so>
main_part2(int, char**) <libHoudiniUI.so>
main <libHoudiniUI.so>
__libc_start_main <libc.so.6>
_start <houdini-bin>
Here's one:
Caught signal 11
perator()(int, siginfo*, void*) const <libHoudiniUT.so>UT_Signal::processSignal(int, siginfo*, void*) <libHoudiniUT.so>
_init <i965_dri.so>
- 41 posts
I reinstalled my machine and the problem is still there. Making me question if it actually ever worked, or was I dreaming?
It seems like the problem is related to tranforms on the object level. Moving points and other components around doesn't make Houdini go down.
I'll report back when I've found a GFX card.
Everyone, thanks for your attention!
