Why is my simulation not showing?
   6499   5   2
Hi all,
I've got a simulation and all looks fine when I'm in the DOP network, but when I go up to the geo level, I see nothing.
The DOP import was all handled by the shelf tools, so everything should be set up correctly. There are no warnings now, but I did have to restart Houdini as the dopimport was giving me a warning before about ‘no DOP object names specified’.
simple_cell_test1.zip (37.5 KB)
1. You should put name of your Dynamic Object correctly in the “Object Mask” parameter !
for your file is :
`dopobjscreatedby("/obj/AutoDopNetwork/sphere_object1“)`
for fixed file is :
`dopobjscreatedby(”/obj/AutoDopNetwork/rbdfracturedobject1“)`
2. Because you used Fractured Object ,So you should Turn Off ”Single Object" Option !
Check Attached FIle :wink:
JK_simple_cell_test_FIXED.hipnc (252.6 KB)
Rabiee.Sadjad@Gmail.Com
I think you made the Dynamic simulation for a simple sphere_object1 first ,Then you changed your DOP network manually and used rbdfracturedobject1 !!!
That got it! I knew you'd come to the rescue Joker
I guess I changed the ‘single object’ option by accident, but I seriously doubt I changed the path of the object mask.
It's quite annoying for me, when I'm trying to debug this kind of stuff, that I cannot click on ‘Object Mask’ and see what
`dopobjscreatedby(“/obj/AutoDopNetwork/rbdfracturedobject1”)`
actually evaluates to, like I can with other expressions.
Joker386
Most likely. Now…I just need to get this to work with solid objects somehow…
Your Welcome My Friend
