Render without background
16583 17 0-
- Hokmah
- 10 posts
- anon_user_37409885
- 4189 posts
- Hokmah
- 10 posts
- 4189 posts
- Sadjad Rabiee
- 1391 posts
Hokmah
Ok thanksI have saved 1 frame for test in exr format but I dont know why when i press Render in mantra node rendering was in the background and I see this process only in Windows Task Manager.In EXR file colors was a little bit different than in Houdini.
When you press render , a new window will open to show your rendering progress (percentage of your render ) , Not only in the Task manager !!!
is it open for you ?
Also if you use simple ip text in the Output Picture parameter for Mantra node , you can see full rendering process in mPlay , But don't forget to save these images to the disk (Use File->Save Sequence As in the mPlay window) , Because they will lost if you close mplay after finishing rendering.
About changing color in Houdini and your exr format , I think that's because different color space in the Houdini and your compositing software.the color space in Houdini is Gamma 2.2 , So you should set Gamma to 0.04545 ( 1 / 2.2 ) in the composite for your exr file to back it to gamma 1.
:wink:
- Hokmah
- 10 posts
- Sadjad Rabiee
- 1391 posts
No ,You can setup Channels for only one Mantra node , Then Houdini will render them one time in one exr file.(Actually this is multiple time in one exr !)
you should go to your mantra node and add Extra Image Plannes in the Properties->Output
You can simply add different passes for lighting (Indirect + Direct) , Z depth , Position , Normals , Reflection , Refractions and etc.
But if you wanna render foam , spray , ocean and etc in the separate pass ,You should do some changes on your project to export these data from Geometries and Material to the Mantra node , then call these data for rendering in the Extra Image Planes.
for example suppose you wanna have different passes for ObjectIDs .
So you can add a custom attribute with same name (e.g JKID) and different value for each object (Foam , Spray , Ocean) , Then export this attribute in the shader (Add a Parameter VOP node and set name to JKID and set Export parameter to Always).
Then add new Extra Image Planes and Set VEX Variable to JKID .
Finally the Mantra take JKID value for each object with it's material and it's Point/Primitive attribute and render this value in the Image !
- Sadjad Rabiee
- 1391 posts
- Hokmah
- 10 posts
- Sadjad Rabiee
- 1391 posts
- Hokmah
- 10 posts
- 4189 posts
- Sadjad Rabiee
- 1391 posts
To unlock background layer in PS , Just double click on it and in the new window which opened , press OK button.
Also if a window (EXR Read Options) opened in the first time , choose "As Transparency" option . in this case Alpha channel use for Transparency in the Layers section.
Another important note is you can just access to Alpha channel (if second option of EXR Read Options activated) in the Channels section ,not Z Depth , Position pass , Normal Pass or similar !
Try to use some Compositing software such as AE ! :wink:
- Hokmah
- 10 posts
- Sadjad Rabiee
- 1391 posts
Hokmah
Yep I know how to unlock PS layer but in this case it doesn't work. All options are grey.. it is only 1 frame because for render this scene in 1280x720 i will need lot of time so I decided to make few good shots with post production
Sorry about that man :roll:
ops: If you can't fix it , upload 1 frame of your exr's , let me check it on my PS :wink:
- Hokmah
- 10 posts
- Sadjad Rabiee
- 1391 posts
- Hokmah
- 10 posts
