the language that we write in houdini (for example in expression ) like this:
stamp(string scop,string token,float value) what is the name of this language and please tell to me the refrence for educating this languge like books or site
please help me
2986 5 2-
- saeed33
- 20 posts
- PradeepBarua
- 443 posts
- PradeepBarua
- 443 posts
Python Scripting with the Houdini Object Model
http://www.sidefx.com/docs/houdini13.0/hom [sidefx.com]
HScript commands
http://www.sidefx.com/docs/houdini13.0/commands [sidefx.com]
Expression functions
http://www.sidefx.com/docs/houdini13.0/expressions [sidefx.com]
HScript commands
- Sadjad Rabiee
- 1391 posts
saeed33
It's expression , now we have two different type of expressions :
1. Old Houdini Expressions
2. Python Houdini Expressions
HScript and Expressions are different , Also each one has different functions and commands !
Expressions Functions :
http://www.sidefx.com/docs/houdini13.0/expressions/ [sidefx.com]
HScript Commands :
http://www.sidefx.com/docs/houdini13.0/commands/ [sidefx.com]
We write Expressions usually in the parameters and Write HScript usually in the Window->HScript Textport
But you can execute Expressions in the Textport with echo command and run Hscript in the Expressions with execute function !
:wink:
Edited by - Nov. 3, 2014 16:56:39
- Sadjad Rabiee
- 1391 posts
Expressions and HScript are very close together (maybe they are same in the syntax , but they are different in commands and functions) , they are pretty like to MEL and Expressions in the Maya , we can use same syntax for conditions and loops in both , But we should use frame word to take current frame in the expressions and we should use currentTime -q; to take frame in the Script editor !
- Sadjad Rabiee
- 1391 posts
Also I suggest you to check this Topic too :
https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=162965#162965 [sidefx.com]
