Render passes for smoke
3034 1 1-
- maxbel
- 39 posts
- Sadjad Rabiee
- 1391 posts
I think this is OK , Just you should make darker your direct_shadow pass in the compositing !
Also when you wanna render different pass for volumes , when stochastic transparency in Mantra node is On , You should set Sample Filter parameter to Full Opacity Filtering for your pass , If don't that , your rendered pass is noisy !
