Install CORRUPTED problem?
   4036   5   1
Apparently my Apprentice is corrupted after only 2 weeks of use!
THIS IS THE ERROR–
HOUDINI CONSOLE:
CUsers/ken/Documents/houdini14.0/config/Icons/SVGIcons.cache' corrupted?
Can I work with it like this? { i can't seem to get rid of the popup }
I tried to reinstall a new version over the corrupted, but I get the same
error.
thanks
Try to clear Houdini preferences folder.
thanks PradeepBarua,
but I dont know how to clear it.
{ of course I see it: edit > preferences }
thanks
Go to your user folder > find houdinixx.xx folder > delete it or rename it like houdinixx.xx_bak.
Make sure your using latest build and GPU drivers.
the SVGIcons.cache is a file created by Houdini when you first run it (or when you change the UI settings)…it's basically the icons for the interface - shelf buttons etc…
it can get messed up occasionally
just delete the Icons folder and Houdini will rebuild it the next time it starts.
Training Lead
www.sidefx.com
thanks a lot all - working now!
