birth probabilty?
   3108   5   1
Hey I was doing a tutorial emitting particles from an object, according to sufrace luminance.
Problem is it references birth probabilty - which seems to have dissappeared or moved in H14.
Any pointers - is it done a different way now?
What's Houdini version on this Tutorial ? Because Particle System in Houdini 13 changed , if you wanna use old particle system , you should use Old-POP Network , then you have Birth Probability parameter in the Source POP node ! :idea:
Rabiee.Sadjad@Gmail.Com
Yes, I was just wondering what the equivalent “modern” method was…
Ok I found it….its under “Emission Attribute”
stardent2000
That's sounds good , Also If you wanna generate some particles from a geometry based on it's luminance (from Texture) , you can use Scatter SOP for generating points on the geometry , then use POP Network for generating particles from these points :idea:
In this case you can generate particles based on luminance for both Old and New POP Network directly 8)
This is a simple example :
JK_POP_from_Lum.hip (223.1 KB)
