I made a mesh decorator object using this dungone as the ‘mesh object’. It
spread the items throughout the dungeon but none were on the floor.(the shot is
after I put them all on the floor).
There's
something in the video about ‘snap it to the terrain’. Is this possible for dungeon
type meshes also?
mesh decorator question
6903 7 1-
- terrymorgan
- 7 posts
- damian
- 402 posts
Not sure about your setup, but in my test, I just place a large Unity sphere underneath the ground plane and then drag the sphere GameObject to the Mesh Object parameter (in the Inputs section) on the Mesh Decorator asset. All the instances then glue themselves to the sphere's surface.
Under the Controls tab on the Mesh Decorator, there are two options that can help fix this. “Lift Source Mesh” will increase the distance the asset looks for a snappable mesh (even if the mesh is given as an Input, the asset won't search infinitely for it). And “Flip Src Proj Dir” will change the direction the asset looks in for snapping the instances. I think 0 is Down and 1 and above is Up.
- terrymorgan
- 7 posts
I think it only works on flat meshes, when I pick the maze dungeon, it
glues to all sides, floors walls ceilings. I'd have to separate out each floor. Might
as well just use the default flat mesh, make my props on a per floor basis, then
drag out the props from the mesh decorator scripts into the main hierarchy,
remove ‘houdini component’ from them all.
- damian
- 402 posts
It does work on non-flat meshes. It just shoots a ray down (by default) until it hits the input mesh you provided (or the default one) and then sticks the instanced object on the ray hit point.
I'm not sure what's going on in your screenshot but ideally, you would not have to remove any “houdini components”. You would, I guess, still have to separate the different floors of your dungeon if it is a multi-level dungeon.
- terrymorgan
- 7 posts
- terrymorgan
- 7 posts
- damian
- 402 posts
- terrymorgan
- 7 posts
Without unity terrain you have no weed painting and probably dozens of other things. Looks like just a dungeon thing then, but I might give it a try on this
http://scrawkblog.com/2013/06/04/massive-terrain-in-unity/ [scrawkblog.com]
