Hey everyone,
Here are my computer specs for reference:
ASUS X99 Motherboard
I7 5930k 3.6 ghz
GTX 980 4GB VRAM
32GB DDR4 2400 MHZ
1TB SSD
I started running a PyroFX simulation and every time I do so, OpenGL crashes after a certain time (around 50 frames). I've looked online and people have said that I don't have enough VRAM on my GPU. If that is the case, how can I allocate more VRAM? The division resolution of the sim isn't that high either (.05).
Every time I even open up the file I get this error right away:
OpenCL Exception: Failed to create compute grid. (-4)
OpenCL Exception: clEnqueueNDRangeKernel (-4)
OpenCL Context error: CL_MEM_OBJECT_ALLOCATION_FAILURE error executing CL_COMMAND_NDRANGE_KERNEL on GeForce GTX 980 (Device 0).
I've also tried using the CPU instead of the GPU because I would have more memory. (http://www.sidefx.com/docs/houdini13.0/news/13/opencl) [sidefx.com] When I put the specific environment variable in I get an error in Houdini saying:
OpenCL Exception: Could not create OpenCL device of type (HOUDINI_OCL_DEVICETYPE): CPU on platform vendor (HOUDINI_OCL_VENDOR): Intel(R) Corporation (-6)
I know I put the information in the correct place because I checked Houdini's Command Line and it was on there. It's pretty frustrating not being able to run a sim for good amount of time on pretty decent machine without Nvidia telling me that it crashed. Not really sure how to fix any of these problems, I am a new user by the way.
I have also attached the file I used to run the simulation.
Thanks for the help in advance!
OpenCL: Won't change from GPU to CPU
10022 4 1-
- Tarun Dhiman
- 16 posts
- anon_user_37409885
- 4189 posts
- Tarun Dhiman
- 16 posts
- 4189 posts
- Tarun Dhiman
- 16 posts
