I am quite new to houdini.
I would like to apply motion to a shaft system.
In the attached files there are two shafts.
Shaft_power and Shaft_supply.Both these have different axis and rotate at the same speed.
How do i connect these shaft. Right now I am using Null node to transform the axis of the inclined shaft(shaft_power).Shaft_power drives the shaft_supply.
I want both the shaft to be perfectly aligned and rotate on their respective axis. The shafts are not in the origin.
Your ideas are welcome.
