Is gtx 960m 2gbRAM good enough for Houdini Animation render?
   3755   3   2
I am currently suffering from rendering animated work from Houdini. I constantly receive “OpenGL Fatal Error” message when I click mantra rendering. I am currently using XPS17 L702x laptop with 1GB graphics card.
Does anyone know how to solve this problem and will a new laptop to solve this?
Or can I transfer my animation into a different software (ie : cinema 4d/ Maya) so that I could still render an animation without having upgrading my laptop into 3GB graphics card?
paris macadama
You should first ensure, that your laptop has no optimus/minimus, WTH that “automatic” switching of onboard/onchip and dedicated graphics is called. That seems to never work.
Second I'd suggest to upgrade your NVIDIA drivers. It should run then.
Also have a look in “Houdini Menu” ->Help ->About Houdini and then click on “Show details”. That should help you narrow your search.
I am torturing my Laptop with a GTX850M/2GB all day long, so should be it in your case too.
HTH
If you can't script/program it, it's no good at all !
WhoDjini
paris macadama
HTH
Thanks for your suggestion and I am trying to work on it now. May I know how can I do this? “ no optimus/minimus, WTH that ”automatic“ switching of onboard/onchip and dedicated graphics is called” Where can I set optimus / minimus and switch of the automatic onboard/onchip?
Open your NVIDIA control panel and under global settings set preferred graphics controller to your NVIDIA. That should do it.
