Hi guys, is it possible to have in computer for Houdini for example one GPU Nvidia Quadro just for monitor and viewport and second GPU AMD for hidden openCL help with simulations? I saw some discussion about GPUs, but didn't find an answer to my question.
I tried that alreday, but there is no ability to select on which GPU I want to use openCL for simulations. It always pick my old Quadro and ignoring the AMD card. There is only enable or disable checkbock. So is it possible?
Thank you very much…
Quadro just for viewport and AMD just for openCL?
3395 4 1-
- Teress
- 23 posts
- malexander
- 5296 posts
Yes, set HOUDINI_OCL_DEVICENUMBER to 1 in your environment variables (or in $HOME/houdini15.0/houdini.env). 0 is the primary graphics card, 1 is the second, etc.
You can then verify that it's using the AMD card by Help > About Houdini, Show Details. Scroll down to the OpenCL section, it should show your AMD card. You can also run the new (in H15) commandline app “hgpuinfo -c” to see your OpenCL info.
- Teress
- 23 posts
- malexander
- 5296 posts
- Teress
- 23 posts
