Everything came in ok except I can't seem to see the UVs.
I have the UV window open but when I select the different geometries, inside the alembic archive node, so that they are highlighted I can't see anything appear in the UV window.
But… to test this I created a generic box and also can't see anything in the UV window when I have this box selected.
So I did a quick tutorial on how to setup uvs. But….
Is there some way to check for UVs that may be already in my alembic object AND do Houdini primitive objects come with a default UV like Maya or do you have to create them every time you create an object?
