The Houdini heightfield asset is imported directly into Unity why not see it?
   7742   14   1
Hello Houdini heightfield assets are directly imported into Unity why not see??
For now, the Unity plug-in doesn't support Heightfields, only the Unreal plug-in does.
You'll need to convert heightfields to meshes first for them to show up in Unity.
Thank you, if you import a mesh file into unity, if you can give the LOD attribute to it,…I don't understand English. I translate it in translation software.If the question is not clear, please forgive me.Thank you for your answer!
how to create digital asset with converted heightfields to word directly in unity?
You'll need to add a “Convert Heightfield” node.
This will convert your heightfield to a mesh, and it will be imported to Unity.
Is there any way to work with heightfields directly as asset in unity or UE?
Edited by Dmitryy Vusatyy - June 1, 2017 16:47:01
The Unreal plug-in supports heightfields.
If your asset contains one, it will be automatically converted to a Landscape by the plug-in.
Unity doesn't support Heightfields “as is” for now, so you will need to convert the Heightfield to a mesh first with the “Convert Heightfield” node.
Thank you very much!!!I also have a question about how the Houdini output height diagram is not. Raw format and.r16 format.Other plug-ins can be used to output such formats.Or is there any other format like these two…
When I follow the tutorial output, the PNG's height map to Unity shows that the details of the mountain range are so badly lost that they appear similar to the pixel grid, which is very bad…
Is this a format problem for the output height diagram, or is there any other solution?Thank you very much!!
Which tutorial are you following? Are you using the heightfield_output node?
If you can attach an example HDA I can try it out.
seelanv
Ok, thank you very much.This is my HDA, and I've got two problems here, 1: I Split the map four copies with a HeightField Tile Split, each individually, and the PNG's height graph.Then find the connecting part of the four height graphs not to the top, the figure!!2: when I import these four Height maps into unity, why does Height Output not Output? Raw and.r16?
HDA is too big to upload, I uploaded the image…Thank you for the
I also have a question in which is it better to output from the heightfield_output node which is a little bit better in Unity?
Since you aren't able to upload the HDA, could you take a screenshot of your graph in Houdini? Just want to understand what you're trying to do.
seelanv
Thank you, I have a question now, and I will import the height map of Unity.The height diagram format is suitable for Unity.Here's my screenshot.Thank you for your patience, because of the translation software, some questions are not clear…
seelanv
Thank you, thank you very much.My problem is solved!!
