i can't fix that the water leaks out through a glass
   3276   3   1
hello, i'm student in japan. i study houdini for myself.
i dont know how to fix that the water leaks out through a glass.
if you know how to fix this issue, please teach me. I would appreciate if you could teach me ..>_<..
You need to give a thickness to the tube and also a decent VDB volume for collision. Other than that, you're pretty spot on with the network setup.
I attached a simple demo of my equivalent setup like yours. Do study it and compare the difference with your setup!
Edited by huey_yeng - March 26, 2018 12:51:01
flipemitter_glass_collision_demo.zip (175.5 KB)
thanks so much huey_yeng!
ill use it as a reference! I realized my lack of understanding about VDB volume.
i really appreciate it ^o^
added “vdb from polygons” between “subdivide” and “collision source”
and changed voxel size in “collision source”
and then set up to Static object>Collisions>RBD Solver>Volume>Mode “Volume Sample”, Division Method “By Size”, Proxy Volume “/obj/glass/VDB”
As a result, this glass could hardly the water leaks out through!
but another problem occurred. The level of water in the glass has gone down..;_;
