Hi
As a beginner of Houdini16.5
I'm so confusing the different between $ and @ for variables
They seem both could be used as a global variables, as well as their definition.
Am I misunderstand their meaning in some way
Help for understanding $ and @ in variables
6379 3 4-
- jessicalorence
- 8 posts
- neil_math_comp
- 1743 posts
All of the things circled in that image are local variables, and they are all different local variables. Most parameters in most nodes do not support local variables; we've been trying to slowly phase them out of anywhere that might need to be evaluated more than a few times per cook, because an expression using local variables can't be evaluated for multiple points/prims at the same time in parallel in the same node cook.
Anything starting with
Things like
Hopefully that helps clear things up!
@refers to an attribute, except for @Frame, @Time, @ptnum, @vtxnum, @primnum, @numpt, @numvtx, @numprim, which were added for consistency with VEX. This avoids the need for the varmap attribute that has been a nuissance for ages. The $Nlocal variable on the Delete SOP [www.sidefx.com] is “The number minus one of points or primitives, depending on the ”Entity“ choice.” The $Ndescription you included in the inset is for ROPs (Render OPerators), not SOPs (Surface OPerators).Things like
$Fand $HIPare global variables, because they work everywhere with the same meaning, instead of having custom meaning in different situations.Hopefully that helps clear things up!
- K Pavan
- 65 posts
ndickson
The$Nlocal variable on the Delete SOP [www.sidefx.com] is “The number minus one of points or primitives, depending on the ”Entity“ choice.” The$Ndescription you included in the inset is for ROPs (Render OPerators), not SOPs (Surface OPerators).
Things like$Fand$HIPare global variables, because they work everywhere with the same meaning, instead of having custom meaning in different situations.
I believe you are Referring about the rangeend parameter field rather than the $N(global variable)
and
I have a doubt on @ptnum
which is mentioned as local variable in doc. Houdini 16.5/ Networks and parameters/ Parameter expressions/ variables and Attributes/ local variables
is @ptnum,@primnum etc.. are variables or attributes or both ?
Houdini Fx Artist (Build)
- Grendizer
- 392 posts
One related thread here : https://www.sidefx.com/forum/topic/57330/ [www.sidefx.com]
Houdini gamboler
