Hi
I am having problem with UI, it appears black partly. I have 4k monitor.
In console appears:
Qt Warn: Warning: QT_DEVICE_PIXEL_RATIO is deprecated. Instead use:
QT_AUTO_SCREEN_SCALE_FACTOR to enable platform plugin controlled per-screen factors.
QT_SCREEN_SCALE_FACTORS to set per-screen factors.
QT_SCALE_FACTOR to set the application global scale factor.
I tried to reinstall houdini, delete the preferences in Documents, reinstall graphic drivers, but no luck. The only solution is to set custom scale for windows under 150 % but then other applications become unusable.
Thank you in advance for help
