Particle Streams Collision
   1679   2   0
Hey Everybody,
I have two particle streams(Emissions from two Objects). They both go into the same popsolver.
After that I want only one of those streams to collide with an object. How can this be done?
Cheers for any help
CYTE
Hi!
I found a solution.
1. In SOP context, you assign an objId to the different object.
2. Inside the popNetwork, use popStream (or pop group) and make reference to the object ID you want to collide.
*Exemple the objectId 1
ingroup = i@objId ==1;
3. Use a pop collision after the stream.
4. wire that stream line to the merge
Let me know if it works. (I attach a basic hip file with the solution)
Cheers!
Edited by morneauju66 - May 7, 2019 09:38:25
particle_Stream_Collide.hiplc (315.6 KB)
Hey morneauju66,
thank you for your effort! it works like a charm. Another solution I found is using a collision ignore after the pop source. but you need two popsources then and it isn't as flexible as your solution. Thanks again!
CYTE
