Fatal Error on start up
   5550   6   1
I've downloaded and installed Houdini 5.5.230 on WinXP and get this meesage when I start Houdini….
FATAL ERROR: Usage: /PROGRA~1/Side <title> <pid>
Please help!
Cheers TC
Hi TC,
Have you tried re-installing Houdini? Also, did you have administrative privileges when installing Houdini?
Please also try re-installing Houdini to c:\houdini5.5.230 if you still get the error.
Cheers!
steven
Hi - I've tried the reinstall under a different directory and get the same error. I also noticed the app appeared briefly with the dialog box stating:
houdini.exe load failed: no such file or directory.
Any more ideas? Cheers TC
Hi TC,
Did you reboot your machine after the installation? Are there any error codes during or after the installation?
May I know where did you download the installation file from? Also, do you have any service packs installed?
Cheers!
steven
Hi Steven - yep I've re-booted and no change.
I got the download from http://www.i-pv.com/downloads/HoudiniNC5_5_230.exe [i-pv.com]
I've got the latest XP service pack….I think.
Cheers TC
Cracked it! I installed under c:\houdini WITHOUT the 5.5.230 and it worked.
Odd eh?
Cheers TC 8)
Hi TC,
Now, that's really odd. :shock:
However, the most important thing is you're able to use Houdini now.
Cheers!
steven
