(Solved) Export OSM data in shapefiles format
   3932   2   1
Using OSM Import SOP I was able to import the OSM vector data.
For reuse on realtime engine I need them to be exported in ESRI Shapefiles .shp format.
I didn't find any tool useful for this work, does anyone have experience on this.
Edited by davide445 - Oct. 8, 2019 08:57:35
AMD Ryzen 5 2600X, 4x16GB 3200 Mhz, Kfa2 GTX 1070 EX 8GB, Windows 10 Pro, KDE Neon
Solved: using QGIS I'm able to read osm file and export in shp format.
A pity can't be done in Houdini (at least I didn't find a node able to).
davide445
How do you get the the OSM file out of Houdini, though? What kind of export do you run from Houdini in order to generate a file that can be used inside QGIS?
