I'm wondering what is the most convenient way to draw on 2D surface? I want to use efficiently a Wacom Cintiq tablet to draw maps directly in Houdini, so rather complex shapes in 2D that I then polywire.
How can I use the “Curve” node on a 2D surface, and lock the Y parameter without having to remap the points afterwards.
Alternatively, I use also in a simpler way Add and I lock the y parameter.
Any convenient tips is welcome. Thank you!
DRAW ON 2D SURFACE USING CURVE / WITH A TABLET & PEN
3757 5 0-
- Cityshake
- 4 posts
- BabaJ
- 2176 posts
- 8213 posts
- Cityshake
- 4 posts
- Cityshake
- 4 posts
- BabaJ
- 2176 posts
If your drawing curves more for the overall shape and don't have too many points to define that shape as a Bezier or Nurbs….
you can drop down a transform node and switch that node to use points and just enter the point number of the curve you want associated.
When you then select the transform node for that specific point controlling the curve change the orientation of the handle to that of the 2D surface and only move the point via the axis handles that are planar.
That way you keep a procedural set up for that curve and can change it viewing from any angle you wish.
Edited by BabaJ - June 12, 2020 01:58:02
