I am using Houdini 18.0.554 Indie
Every time I access a node, I receive a <nodename>.dialog.ui error
Example:
WARNING: Cannot create C:/Users/ax/Documents/houdini18.0/config/Dialogs/18.0.554/SOP/null.3. (No such file or directory)
WARNING: Cannot create C:/Users/ax/Documents/houdini18.0/config/Dialogs/18.0.554/MWS/null.dialog.ui. (No such file or directory)
WARNING: Cannot create C:/Users/ax/Documents/houdini18.0/config/Dialogs/18.0.554/MWS/null.dialog.ui.3. (No such file or directory)
WARNING: Cannot create C:/Users/ax/Documents/houdini18.0/config/Dialogs/18.0.554/DM/xform.dialog.ui. (No such file or directory)
WARNING: Cannot create C:/Users/ax/Documents/houdini18.0/config/Dialogs/18.0.554/DM/path.dialog.ui. (No such file or directory)
WARNING: Cannot create C:/Users/ax/Documents/houdini18.0/config/Dialogs/18.0.554/SOP/xform.3. (No such file or directory)
WARNING: Cannot create C:/Users/ax/Documents/houdini18.0/config/Dialogs/18.0.554/DM/noparentalignxform.dialog.ui. (No such file or directory)
WARNING: Cannot create C:/Users/ax/Documents/houdini18.0/config/Dialogs/18.0.554/SOP/chopnet.3. (No such file or directory)
WARNING: Cannot create C:/Users/ax/Documents/houdini18.0/config/Dialogs/18.0.554/MCS/chopnet.dialog.ui. (No such file or directory)
WARNING: Cannot create C:/Users/ax/Documents/houdini18.0/config/Dialogs/18.0.554/MCS/constraintpath.dialog.ui. (No such file or directory)
WARNING: Cannot create C:/Users/ax/Documents/houdini18.0/config/Dialogs/18.0.554/CHOP/constraintpath.3. (No such file or directory)
I am unsure how to fix this error, the software continues to work 100% without fault, the error is simply annoying.
Please assist.
Regards
Alex Amos
