I am trying to change several parameters at once with the selected nodes and it is not changing like before, am I missing something?
Thanks.
Change several parameters at once H18.5 issue
4933 9 0-
- mzigaib
- 1040 posts
- 8192 posts
- mzigaib
- 1040 posts
- mzigaib
- 1040 posts
- mzigaib
- 1040 posts
UPTADE:
More digging and I found out that it has something to do with older custom Desktops I think there's some new option that has something to do with “synch” nodes that 18.5 now has that 18.0 didn't I am trying to find which and where it is. If someone know something about it be welcome to share.
Thanks.
Thanks.
- 8192 posts
- mzigaib
- 1040 posts
jsmackI just want make sure that it is a bug but I think it is.
can you submit a bug?
The image shows some parameters ui components behaving weirdly on the same houdini 18.5 session.
I just split top bottom and used the “P” to call the parameter ui in the bottom pane.
The top pane is showing a grey value because the 3 parameters have different values the bottom don't.
Edited by mzigaib - Oct. 23, 2020 15:42:19
- mzigaib
- 1040 posts
- 8192 posts
- gkwilliamson
- 6 posts
