Issues with All viewport Flipbooking with motion blur ON
   3785   3   0
Hi all,
I ran into an issue today when trying to flipbook All viewports, with Motion Blur on. The flipbook result only contains partial of ONE viewport.
With motion blur OFF, I can see the result of all viewports.
I've tested with both 18.0 and 18.5.
Is this a known issue or I miss something in the set up?
Additionally, where Houdini store the default/original setting for Flipbook? Is there an way I can query this via `hou` package?
Kind regards,
Tung
Edited by tung - Nov. 23, 2020 15:26:59
Unfortunately the flipbook can't do motion blur when rendering all viewports. That option should really be disabled when rendering all viewports.
twod
Thank you for your response. I am wondering if there is a plan to support this in the future?
If you dont mind, may I have another question.
Where Houdini store the default/original setting for Flipbook? Is there an way I can query this via `hou` package?
Regards,
Tung
Edited by tung - Nov. 23, 2020 15:41:00
tung
twod
Probably not, it would require a pretty large rework of how “all viewports” mode is rendered.
The defaults are saved to $HOME/houdiniX.Y/flipbook.pref. They can be set or queried interactively via hou.SceneViewer.flipbookSettings() on a valid SceneViewer object. It accesses a FlipbookSettings object.
