I'm trying to create a gradient look where I have a box scattering along my geometry via 'copy to points' and want to have the bottom part rescale to something small, and the top rescale to a larger size. So the box scatter would shrink as it gets lower on my geometry.
But I can't figure out a way to do that with a 'soft' transition. I'm new to Houdini still, but the closest I got was to use a group - bouding box - plugged into an attribute random. But its a very harsh line. What do I do to soften this?
Creating a soft gradient 'attribute randomize' pscale?
3234 2 2-
- ninamarievisuals
- Tanto
- 545 posts
I'd use a point wrangle node to establish a base pscale on your emitting geometry.
Something like:
Then click on the small slider icon at the right of your code to get sliders for your minimum and maximum size, and a ramp for the falloff.
Then if you want to add randomness, you can use an attribute noise down the graph with operation set to multiply.
Hope that helps.
Something like:
float minsize = ch('min_size'); float maxsize = ch('max_size'); f@pscale = fit01(chramp('pscale_over_y', relbbox(0, v@P).y), minsize, maxsize);
Hope that helps.
Edited by Tanto - Jan. 31, 2022 12:57:14
- eikonoklastes
- 447 posts
