Hi everyone. I don't know what to do. Maya does not recognize Houdini plugin
// Error: file: C:/Program Files/Autodesk/Maya2020/scripts/others/pluginWin.mel line 935: Unable to dynamically load : G:/APPS/SideFX/Houdini Engine/Maya/19.0.383/maya2020/plug-ins/houdiniEngine.mll
The specified module could not be found.
// Error: file: C:/Program Files/Autodesk/Maya2020/scripts/others/pluginWin.mel line 935: The specified module could not be found.
(houdiniEngine) //
// Warning: file: C:/Program Files/Autodesk/Maya2020/scripts/others/pluginWin.mel line 938: Could not load G:/APPS/SideFX/Houdini Engine/Maya/19.0.383/maya2020/plug-ins/houdiniEngine.mll as a plug-in //
installing just the houdini engine maya plug in
21582 35 4-
- Roumonk
- 6 posts
- johnmather
- 679 posts
- Roumonk
- 6 posts
- Grendizer
- 392 posts
- Roumonk
- 6 posts
- Roumonk
- 6 posts
- johnmather
- 679 posts
- Roumonk
- 6 posts
- kustaa
- 47 posts
I just installed 19.0.531 and i cant get the plugin loaded in maya 2020.4 windows.
I installed houdini to the default suggested location.
if i try to load the plugin from the pluginwindow list i get this:
// Error: file: C:/Program Files/Autodesk/Maya2020/scripts/others/pluginWin.mel line 317: Unable to dynamically load : C:/Program Files/Side Effects Software/Houdini 19.0.531/engine/maya/maya2020/plug-ins/houdiniEngine.mll
The specified procedure could not be found.
// Error: file: C:/Program Files/Autodesk/Maya2020/scripts/others/pluginWin.mel line 317: The specified procedure could not be found.
(houdiniEngine) //
if i manually browse to the plugin and try to load it i get this.
// Error: file: C:/Program Files/Autodesk/Maya2020/scripts/others/pluginWin.mel line 935: Unable to dynamically load : C:/Program Files/Side Effects Software/Houdini 19.0.531/engine/maya/maya2020/plug-ins/houdiniEngine.mll
// Error: file: C:/Program Files/Autodesk/Maya2020/scripts/others/pluginWin.mel line 935: The specified procedure could not be found.
(houdiniEngine) //
// Error: file: C:/Program Files/Autodesk/Maya2020/scripts/others/pluginWin.mel line 894: Object 'pluginManagerWindow|windowLyt|scrollLyt|parentLyt|PluginFrameLytMisc|PluginFrameLytMisc|PluginRowColLytMisc|plugLoadedChk82' not found. //
// Warning: file: C:/Program Files/Autodesk/Maya2020/scripts/others/pluginWin.mel line 938: Could not load C:/Program Files/Side Effects Software/Houdini 19.0.531/engine/maya/maya2020/plug-ins/houdiniEngine.mll as a plug-in //
I can manually still load the 18.0.348 plugin in maya.
any thoughts how this could be fixed?
(houdiniEngine) //
(houdiniEngine) //
Edited by kustaa - Feb. 23, 2022 03:59:02
- kustaa
- 47 posts
- johnmather
- 679 posts
- kustaa
- 47 posts
- kustaa
- 47 posts
- johnmather
- 679 posts
- kustaa
- 47 posts
- johnmather
- 679 posts
