update paths/links in Edit LOP?
1392 0 0-
- syncronos_design
- 3 posts
Is there a way to alter the paths or names of objects in the Edit LOP? For example, if I use it to lay out a scene, but then later need to change the name of an object or path, the edits break, and there doesn’t seem to be a way to update it. In other nodes I can access the exact path and/or primitive so can update things without losing my work. I even tried “opchange” but that doesn’t seem to recognize anything in the Edit LOP. For now, the only way seems to be revert the names back to what they were, or to redo all the layout edits.
