Vellum dynamic restlength by attribute
   5216   5   2
I am trying to change the restlength dynamically during the sim using an attribute. I am creating the mask attribute on the constraints on Sop level and then referencing that inside the Vellum solver with a geometry wrangle running over prims.
Doesn't seem to work, but can't figure out why. Any tips?
vellum_dyn_rest.hiplc (544.1 KB)
I'd use a Vexpression to assign the restlength, and a popwrangle to manage the Cd.
It's not very pretty, but here's proof of animated MOPs attribute transfer.
Check out this topic, too:
https://www.sidefx.com/forum/topic/87302/ [www.sidefx.com]
Edited by Enivob - Nov. 16, 2022 16:23:58
ap_vellum_dyn_rest.hiplc (570.7 KB)
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
yeap! thank you vellum constraint properties did the trick. not sure why i couldn't get it to work with a geometry wrangle though
The order of prims are changed when Vellum starts to solve. That's the reason why just copying the values over from Sops doesn't work. A custom prim index attribute could help identifying the correct pairs of constraint prims.
https://behance.net/derya [behance.net]
Here's an enumerate to get the custom index attribute and the geo wrangle to get the mops mask affecting restlength:
vellum_dyn_rest_yader.hiplc (545.5 KB)
that makes sense! thanks a lot Yader
