Saving HDA's to the job
   4151   5   2
Hi all!
I'm trying to save HDA's that are specific to a project, within the $JOB file structure. But I've run into some trouble where they don't seem to be loading.
In the docs it says that it should work, but it seems that Houdini isn't loading the HDA's from the Job/HDA folder
Docs… [sidefx.com]
You can put assets specific to a project in $JOB/hda. See project management for how to set up $JOB
Any ideas what I'm doing wrong there?
Thanks,
Pete
Edited by peteski - Feb. 4, 2017 23:17:53
Have you set the $JOB variable in the HIP that is supposed to load them?
File\Set Project… then save.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Hmm, just tried that and it seems it still doesn't add the HDA's from the Job path.
P.
It sort of works, but you have to name the folder $JOB/otls Then you have to set the project, save your file and reopen it. It's probably easier to create a simple package now...
I was looking for a solution for this now for a while.
There is a Python script by Chris Gardner which will allow you to load the otls from your $JOB directory.
https://gist.github.com/chris-gardner/c9daf34a668c5dddda94b9f6276d8cb8 [gist.github.com]
Stumbled upon here: https://www.tokeru.com/cgwiki/HoudiniHDA [www.tokeru.com]
The Script needs to be copy paste in: Windows -> Python Source Editor
The original script will create a error (at least for me).
Here the adaptation of it which worked for me:
NOTE: depending on the license version of your files you need to adapt the filetypes. Also in the $JOB directory there needs to be a "otls" folder containing your assets (no subfolders)
import hou
import os.path
def loadHdaLibrary(libPath):
    Loads all the HDA files in a folder
    @param libPath: HDA library file path
    if not os.path.isdir(libPath):
        print(libPath)
        return
    loaded_files = hou.hda.loadedFiles()
    # Get all the .otl files in the directory.
    filetypes = ['.otllc','.otl','.hdalc','.hda']
    otl_files = [f for f in os.listdir(libPath) if os.path.splitext(f)[1] in filetypes]
    for otl_path in otl_files:
        # backslashes are the devils work
        full_path = os.path.join(libPath, otl_path).replace('\\', '/')
        # If the file isn't already loaded, install it.
        if full_path not in loaded_files:
            #print 'installing', full_path
            hou.hda.installFile(full_path)
loadHdaLibrary(hou.getenv('JOB')+'/otls')
Awesome, thanks for this. I'll have to have another look!
