Rendering problem help!
   1013   0   0
-image 1-
-image 2-
hello
While listening to the Houdini tutorial (https://www.youtube.com/watch?v=Ohj4ag8DZRo&t=26s), I had a question about rendering!
In the tutorial, redshift is used to render, but I don't have redshift, so I rendered with octanerender.
After rendering, I looked later and saw that everything had been rendered as Image 1.
It was clearly set to Image 2 in the IPR.
I looked around to see if the settings were wrong and tried various things (file caching the simulation, maximizing the focus value, etc.) and found one thing that was the most meaningful.
If I set it to render frame range, it comes out as image 1, and if I set it to render current frame, it comes out as image 2.
(If I turn everything at once, it comes out strangely, and if I turn it one by one, it comes out as I want.)
I would like to ask if this can happen and if there is a solution.
I wondered if this was happening because it was rendered while calculating something like VEX code, so I ran a file cache and turned on the rendering, but it continued to render like that.
Please help. Thank you!
