I've set up an OpenGL rop to do a playblast.
From Hython if I try to run
hou.node("/out/opengl1").render()
I get the following error
OpenGL Fatal Error: The installed OpenGL driver is not able to run OpenGL 3.3. Please update the driver and check the minimum system requirements for Houdini (www.sidefx.com/sysreq)
I'm running a 3090 with Nvidia 510 Drivers
❯ glxinfo | grep "OpenGL version"
OpenGL version string: 4.6.0 NVIDIA 510.47.03
Is this because nvidia added limitations to Gtx/Rtx cards?
Cant run OpenGL Rop from hython on Ubuntu 20.0
1961 2 0-
- vexalot_
- SMC7192
- 44 posts
- gangland
- 3 posts
SMC7192
Hello
I had this problem in top with rop opengl
To fix this problem you need to install all opengl and opencl libraries
to do that :
sudo apt install opengl*
sudo apt install opencl*
* means taking all opencl and opengl libs
I hope i helped you
Thanks dude, it really worked, im shocked.
You're a genious, thank you so much
