Edit graph script edit node's parameters
   1422   1   1
Hi, how do I change parameters when I create a node using "add node"?
parameters like translation of the transform object I created etc, there is a dict parameter input but how do we use it?
thank you
Edited by anon_user_09389530 - May 24, 2024 16:52:33
Screenshot 2024-05-24 164853.png (124.9 KB)
I contribute to the beauty of this world
https://houdininotes.ivanlarinin.com/ [houdininotes.ivanlarinin.com]
Check out this link, I explain it there (about 15 minutes into the video) https://youtu.be/3XtT1BRpq2k?si=lRCvqGhS8pItnm2H [youtu.be]
In the case of a transform object, you’d create a transform build node, adjust the translation, plug that into the dict build and change the input name to “restlocal”.
The value type (matrix 4x4, vector, sting etc) and name have to match the node’s input parm you want to update.
