Auto-rig Hand Print Path override
   2887   1   1
Does anybody know how to get the Hand Print Path ik override to work on the Auto-Rig? Or the body_part_arm DA for that matter…same thing.
No matter what I put I put into the path (null, geometry, etc) wrist will only blend towards the origin. The object seems to have no affect. Tried object level and sop level transforms. This is with Houdini Escape 8.1.746.
ofcourse, wouldn't you know..soon after I post I finally figure it out. :roll:
Seems that there is a separate body_part_arm_hand_print that can be used. It is interesting that only that works for the override. Also the auto-rig doesn't automatically create it and the Doc's are a bit vague, not specifically stating that body_part_arm_hand_print should be used.
