I'm trying to remove an incoming sublayer using Find Sublayers / Remove Found Sublayers as described in the docs for the Sublayer node. Is there any particular trick to the patterns that are accepted? I've tried things like "*mySublayer*", "*/mySublayer.usd", as well as the full path as displayed in the Scene Graph Layers panel. None of these seem to have any effect. The layer I want to remove does already exist on disk, so it seems like it should work despite the caveat in the docs.
I'm in 19.5.569 on linux. Thanks!
How to remove a sublayer
3161 6 2-
- Alec Bartsch
- 3 posts
- Alec Bartsch
- 3 posts
Follow-up question: is "removing" a layer the same as "muting" it, under the hood? I was able to work around the problem by doing this in a Python Script LOP:
node = hou.pwd()
stage = node.editableStage()
stage.MuteLayer (node.evalParm("setsLayer"))
But it's not an ideal solution because of the way python LOPs sometimes cook and sometimes don't.
node = hou.pwd()
Alec Bartsch
- cdordelly
- 209 posts
You can use the Configure Stage LOP to mute layers:
I haven't used it before but looks like it does what you are looking for.
Cheers!
Cheers!
- mtucker
- 4568 posts
There was a bug in the sublayer removal code that made it not work in some cases where you want to remove multiple sublayers. This was fixed in 20.5, but the fix was not backported. But if you're only removing a single sublayer, then I would expect the Sublayer LOP to be up to the task.
Muting (conceptually) can have an equivalent effect, but goes about it in a very different way. In particular, muting information is not stored in the USD stage, so when you save the USD the muted layer will "come back", but a "removed" sublayer will stay removed. Further, muting with python the way you've done it there is completely unsupported in Solaris. It may appear to work for a little while, but will break at some point. The Configure Stage LOP can mute layers in a "Solaris friendly" way, if muting is in fact what you want to do, but layer muting doesn't support the use of wildcards in the layer path. You would need to explicitly specify the full path to the layer(s) you want to mute.
- Alec Bartsch
- 3 posts
Ah interesting, so it sounds like "removing" is doing some kind of list-editing on the sublayers metadata? For my use case muting an explicit path is just fine, and Configure Stage is working great. Thanks Mark and cdordelly!
Just to confirm my understanding, if Sublayer were working as advertised then either a pattern like */set.usd or an explicit path should be ok?
Alec Bartsch
- mtucker
- 4568 posts
Yes, "removing" is actually editing the layer metadata that lists the sublayers composed onto the stage. This may be a good or bad thing, depending on whether you want to modify the USD layer permanently, or just turn off the layer for the current Houdini session (in which case muting is probably the right approach).
And yes, sublayer removal should (and in 20.5 I would claim that it does) support patterns like "*/set.usd" or an explicit path.
- adrianmeyerart
- 37 posts
sublayer removal does not seem to work (I'm on Houdini 20.5.487).
Neither patterns like
*/set.usd
nor absolute paths work for me.
It's a super crucial feature for exactly the case how the feature is described in the docs of the sublayer node. @mtucker could you be so kind and verify this?
Is there any other way to solve this scenario?
(layer muting doesn't work here as described above)
*/set.usd
Turn this on to remove any layers that match the patterns the Find sublayers.
This is useful if you want to replace layers rather than just add them. For example, you may be editing a layer that has sublayers for animation, effects, and lighting. If your LOP network generates a new version of the effects layer, you would want to remove the existing effects layer and replace it with the new one.
