For loop connectivity struggle
   856   3   0
Hello.
I'm having some difficulty in connecting ports within a for loop.
What i'd like do in one component script is -
Add a subnet between 2 TransfromObjects. But for multiple sets of objects with unique tags
For instance
index_joint0 > subnet > index_joint1
middle_joint0 > subnet > middle_joint1
pinky_joint0 > subnet > pinky_joint1
I can hook up the subnet to one joint, but struggling with the logic to hook it up correctly to both.
Any steers in the right direction be much appreciated
scene attached
connectivity.hip (423.0 KB)
here is one solution if I'm understanding correctly what you want .
Edited by MatijaK - March 13, 2025 02:19:03
connectivity.hiplc (416.0 KB)
This solution is more what are you searching I think.Hope it helps
Edited by MatijaK - March 13, 2025 02:19:34
connectivity02.hiplc (416.1 KB)
MatijaK, thankyou.
That is exactly it.
I'd managed a workaround but not nearly so elegant.
This is perfect.
