Breaking glass
   920   3   1
I'm trying to sim some breaking glass with the "rbdbulletsolver", and to prevent the cracks in the transparent fractured glass from showing in the render before they actually break, I use the "rbdconnectedfaces" and "rbddisconnectedfaces" so the cracks only show up where the glass is actually broken.
But it seems this setup with the "connected" and "disconnected" SOPs is not compatible with the "rbdconfigure" I use to tweak the material settings and timing, because when I enable this SOP the cracks in the glass show up everywhere.
Is this a bug, or does anyone know the secret to make a setup like this work ?
RBD Configure Packs the Pieces
RBD Connected Faces expects unpacked geo so that it can detect the face proximities, therefore it will not work after Configure
so the order you want is
RBD Connected Faces
RBD Configure
RBD Solver
Unpack
RBD Disconnected
CG Supervisor
Framestore, NY
Brilliant, thanks.
I guess I thought that is what disabling "create packed fragments" does in the RBDconfigure settings.
toonafish
RBD Configure always creates packed primitives as all the configured properties are stored on their points as attributes
disabling creating Packed Fragments creates Packed Geometry primitives, so just a different type of Packed Primitive
Edited by tamte - Sept. 24, 2025 00:21:43
CG Supervisor
Framestore, NY
