Apex autorigbuilder - turn off stretchy spline/spine?
734 6 1-
- phinnaeus
- 6 posts
- william_harley
- 131 posts
- phinnaeus
- 6 posts
- phinnaeus
- 6 posts
Yes thanks for this but its lacking the extra adaptable controls that the Autorigbuilder gives. (up to 12)
I've found that Snakes typically need at least 8 or more depending on the animation.
I've tried adding adding Custom Num Controls but that seems to break the autorigcomponent as it requires only 4.
Also I'm using the spine component for the area around the head for additional control of this area. Not sure if this is the way to go with snakes but its also missing a 'Turn off' add stretch control.
Edited by phinnaeus - Feb. 2, 2026 17:32:33
- phinnaeus
- 6 posts
- william_harley
- 131 posts
Custom works, you just have to be mindful of the curve order. I explain how the curve order works for the spline here => https://www.sidefx.com/forum/topic/96509/ [www.sidefx.com]
- phinnaeus
- 6 posts
