anamorph a file .mov from 4:3 to 2.35:1
   4069   1   0
I would like to anamorph a video (the extension is .mov) from 43 to cinescope 2.351 (like tarantino's movies). is it possible by houdini? If yes, how do?
sorry for my bad english but i'm italian and i don't write it very well…..
thanks
bye by FIL
mjjfil
I would like to anamorph a video (the extension is .mov) from 4:3 to cinescope 2.35:1 (like tarantino's movies). is it possible by houdini? If yes, how do?
thanks
bye by FIL
First, Houdini cannot handle Quicktime movies (.mov). You may need to purchase Quicktime Pro from Apple. It will allow you to save the .mov file to various other formats.
What is the resolution of your source file? What resolution do you want it to be? When you export you can customize the size and I believe there is something there for aspect ratio (maybe letterbox it?).
If you really wanted to use Houdini, use QT Pro to save an image sequence thru it's export options (you can save to jpeg, tga, bmp). Then load this sequence in COPs and do your own cropping.
Good luck.
Rob
Rob
Digital Supervisor | Stargate Studios Toronto
