I need some help with shaders and shading
6998 5 1-
- calin
- 114 posts
I'm trying to render a glass and maybe some caustics. Can someone please tell me how to use this things in houdini (btw. they are not documented so well, except ambient occlusion) because I used the glass shader and it's cool as long as I don't render with shadows (the shadow is black no matter which shadow filter I'm using) and when I want to render from inside the glass only the reflection map is rendering (no transparency). I must admit I'm kind of lost here because I don't fully understand the way that Houdini works with ray tracing/transparencies/caustics
- tallkien
- 225 posts
- edward
- 8122 posts
There's a GI with caustics video here:
http://www.vislab.usyd.edu.au/sidefx/houdini_video/by_topic/rendering/index.html [vislab.usyd.edu.au]
- tallkien
- 225 posts
- calin
- 114 posts
thx, for the link, caustic works fine now. But I still have the transparent shadow and glass shader BIG problem. If I use a glass shader the shadow is opaque even if I use texture shadow as a shadow shader(too bad there is no video tutorial about shadows and raytracing). Basicaly I have a glass object and inside a opaque object. Now what I expect to see in the shadow is a nice transparent shadow (a little less transparent to the edge of the glass shadow) and a opaque shadow of the opaque object. There must be a way of doing this but I'm affraid I don't know how to do it
Can someone please help me.
I've try to build a vex glass shader from scratch (like connecting facing forward or fresnel to bouth color and opacity) but it was a total fiasco.
In my opinion this capitol (rendering raytracing and some dumb vex shader creation for transparent/translucent objects like glass, water or ice) needs some more tutorials because I find myself a bit lost in the way that houdini renders
- MatrixNAN
- 405 posts
Tutorials on Shadows Rendering and optimisization.
http://www.sidefx.com/community/learn/rendering/index.html [sidefx.com]
Nate Nesler
Nate Nesler
