patterns per side of building?
   657   0   0
I'm testing out the labs building from patterns to set up some simple house models, and I'm wondering if there is a way to create a pattern or method that allows me to treat each side individually? I cannot seem to come up with something good here. It seems that the patterns we can create apply to every single section of the building. So, am I missing something here or is this a limitation of the node? I also tried to input a grid instead of a box, and that does not work. So, is the only real option here to create 4 entirely separate versions of the model, then delete the portions according to which wall pattern I need, to then re-combine them into a new model? This sees very convoluted, so if anyone has any tips for a better way of doing this I am all ears!
Dag
