convert tiff to rat
   10108   4   0
Hello ,
how can I convert my tiff texture to rat format?
using H9
thanks,
bern
Command line function called “icp” - or use Halo.
you can open it with the image viewer and simply save it as .rat
Stephen Tucker
VFXTD
Yep:
icp myimage.tiff myimage.rat
is probably the simplest way to do it, assuming you have a decent shell available. Otherwise, load it in mplay, then use File->Save As to save it as “myimage.rat”.
ps - Halo is the compositor (COPs) which would be the most involved way to do it (workflow-wise) but would work well for many tiff->rat conversions.
Hi, there are two rat formats at mplay: rat and mip map rat. Is the simple rat also pyramidal as mip map rat? Or there are some other reasons between this two formats?
Houdini is great! O'right?
