Clicking On Work Item on BlackBoxed HDA
   624   2   0
I am making a Blackboxed HDA and I need to be able to click on the work item. How can I accomplish this while maintaining a Blackbox? It just says permission denied at the moment.
Edited by VGriffith - April 9, 2025 13:41:10
Did you make a copy before turning it into a Blackbox HDA? the unfortunate part of Blackbox is everyone is locked out to stop people changing or copying stuff so you can securely distribute the files for use.
think of it as the Blackbox on a plane VGriffith airways fits the blackbox
the plane goes down because of a engine failing as a mechanic messed up.
VGriffith airways doesn't want the mechanic to change the data to say the pilot was doing loop the loops. hence it's a locked system
it would need a new black box to say the pilot was doing loop the loops.
Yes I have the original HDA. I know what a blackbox HDA is, I just was hoping someone could help me select a work item on a blackbox HDA. Obviously the changes need to be made on the original HDA (that I have)
Edited by VGriffith - April 10, 2025 09:03:42
