Understanding the use of Visualize node in Material Builder
   855   0   1
Hi everyone,
I'm new to Houdini and trying to learn it. I already have some experience in Blender.
One thing I'm trying to understand is how the Visualize VOP Node works with Karma Ramp Constant node in the Karma Material Builder context. In Blender, I can just Ctrl + Shift + LMBto view any node (the Color Ramp in this case) without being in the rendered view. However, in Houdini, when I try to visualize the Karma Ramp Constant node by pressing X, the mesh disappears completely.
Here is my material's texture visualized, which works like I'd expect,
However, when I try to visualize the Ramp, the mesh just simply disappears like below,
Even if I connect the Ramp to the Standard Surface shader, the texture doesn't show in my viewport. However, if I don't use the Ramp Node, then the texture shows up in the viewport.
Also, when I go to the rendered view using Karma CPU/XPU, the texture shows up with the ramp applied correctly like below,
I tried setting the Ramp signature to Vector, then the mesh disappears again in viewport, but works when in rendered view.
I'd like to know about how you guys usually go about creating materials.
So here are my questions,
  1. Does the Visualize node works for some node and not others? How do I know?
  2. Do I always need to be in the rendered view to work with materials? My CPU is not that fast, and the Optix compilation in XPU for every single change in material is a time hog.
  3. If I use ramp to adjust color, my texture doesn't show up in viewport, is this expected?
Thank you for any help!
