I'm trying to use the light placement modes but none work when I click on the shader ball, the light doesn't move. I tried resetting the viewport, restart render, switch back to OpenGL ... Any ideas ? I'm using Houdini 20.5.550 Thank you
y0unesss2010 I'm trying to use the light placement modes but none work when I click on the shader ball, the light doesn't move. I tried resetting the viewport, restart render, switch back to OpenGL ... Any ideas ? I'm using Houdini 20.5.550 Thank you
Did you ever find a fix for this? I'm having the same issue
